- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Upgrade router with Orbi RBR40
- Mark as New
- Bookmark
- Subscribe
- Permalink
My existing modem is a C6220 (AC1200). I have an Orbi RBR40 and 2 satellites. My modem is not rated high enough for my internet service so I want to upgrade to CM700. My Orbi is not supported by Netgear any longer. My thought is to save replacing my Mesh system is to get a new router and place that between my modem and the Mesh.
Will the Mesh still be able to use the satellites? Will the system work? I am trying not to but a new Mesh
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Upgrade router with Orbi RBR40
What speeds are you paying for and who's your isp?
It might be just worth upgrading the modem and keeping the orbi if its meeting your needs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Xfinity 1200 down.
I also worry about security even though I do have Armor. I definitely want to have a router that will have firmware updates
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
the cm700 doesn't support multigig on xfinity.
I'd look at getting one of the next gen devices that xfinity supports for your modem.
knowledgebase/next-generation-internet - Comcast_Xfinity (reddit.com)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks. The reason I didn't go with a higher modem is the Orbi RBR40 only goes to 866mbps. Would the Orbi/satellites work in the configuration I am suggesting? Chain Modem- New Router-OrbiRBR40/satellites
- Mark as New
- Bookmark
- Subscribe
- Permalink
Even if you don't go multigig, you should still at least go to to docsis 3.1. That'll at least get you gigabit.
And if all you're doing is the cm700, its pointless to upgrade the router as it'll have no problem handling the cm700.
- Mark as New
- Bookmark
- Subscribe
- Permalink
WIll my RBR40 present a security issue since it is not supported any longer?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think, "not especially." No Netgear router accepts connections from the internet. Most vulnerabilities are from the LAN side and highly technical. I do not lose sleep over the security of my 8 year old Orbi router.
