Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WPA3-Enterprise support A8000/AXE3000 wifi 6E usb adapter
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-05-25
08:38 AM
2023-05-25
08:38 AM
I am trying to test with the A8000/AXE3000 wifi 6E usb adapter running on a windows 11 machine and connecting to a 6Ghz AP/Router that supports WPA3-Enterprise with a Radius server. I attempt the connection and the Radius server accepts the EAP-PEAP,EAP-MSCHAPv2 authentication but the windows 11 client never connects.
Does anyone know if this adapter supports WPS3-Enterprise ?
When I run netsh wlan show drivers, the Authentication and cipher supported in infrastructure mode for WPA3 only shows WPA3-Personal.
Message 1 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2023-05-25
09:30 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2024-05-13
05:55 PM
2024-05-13
05:55 PM
Re: WPA3-Enterprise support A8000/AXE3000 wifi 6E usb adapter
I spent hours trying to resolve this, not sure if you’re issue is the same, but what I eventually discovered is that the drivers for this product support windows 11 on ARM64, which is what I operate. They support Windows x86. Long story short there are some drivers that support ARM64, I haven’t done enough testing to find on that works yet, I know that Realtek has some, that’s where I’ll be starting.
Hope this helps. NETGEAR needs to get either times and upgrade their driver software.
Message 3 of 3
Announcements
