- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk M6 Pro heat mitigation
- Mark as New
- Bookmark
- Subscribe
- Permalink
Having troubles with heat warnings on the M6 Pro while using outdoors. The two things I’m considering doing are: removing battery and powering with power bank and/or turning off WiFi on the hotspot and running Ethernet to a mobile router with an internal fan.
Anyone have any experience with M6 Pro overheating? What was the solution?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk M6 Pro heat mitigation
@g1omaa wrote:Having troubles with heat warnings on the M6 Pro while using outdoors. The two things I’m considering doing are: removing battery and powering with power bank and/or turning off WiFi on the hotspot and running Ethernet to a mobile router with an internal fan https://vlc.onl/.
I got this,...
