- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
r7800 with DomaOS A7Legit V2.3.2.22
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, how do I put netgear official firmware back on my Knighhawk X4S R7800 that has DumaOS A7 V2.3.2.22 firmware on, it wont tftp back to netgear early versions. Novice needs HELP!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
well you might have a beta unit that is locked because its a beta. Like I said, I've only ever since it on the r7800 on those beta units.
you might be sol.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: r7800 with DomaOS A7Legit V2.3.2.22
The R7800 never officially supported dumaos. I think it was only on some beta units.
So you might not find any info on how to clear it.
reason you don't want dumaOS?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi its just surfing awa found several people said it was unsafe. Plus I cant seem to get it to take Surfshark VPN on tried with Openvpn set but wont take it. But otherwise I cant fault it setup was very easy to do seeing as I`m only a novice. Just wish I could get Surfshark on it as I`ve 18month subs left on it. instead of putting it on everything that goes thru internet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
you might be sol.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
tftp can be sensitive to timing. You might have to try a few times.
You can also try nmrpflash.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/000059633/How-do-I-upload-firmware-to-my-NETGEAR-router-using-a-TFTP-client-o...
https://kb.netgear.com/000059634/How-do-I-upload-firmware-to-my-NETGEAR-router-using-TFTP-from-the-M...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, thanks for the reply a problem I have when I TFTP is when I reboot the router the power light lights up orange but dose NOT BLINK it just changes to white when loaded up and other lights turn white. So what I have done is entered the PUT command at different times after rebooting ie every 5 seconds after power lights orange : 5 - 10 - 15 - 20 ; 25 seconds & so on. I have put some hours into this still no joy I must be missing something. Fingers are wearing out retyping the command line. I`ve tried both the TFTP as described on last answer several times.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I`ve also tried with and without enabled TFTP in Windows Optional Features,
what i`ve noticed in all references to the firmware file as being (.chk) where as
for the R7800 firmware they are all (.img) files that I am trying to TFTP.
BED for me now try again tomorrow, thanks everyone for todays help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
just tried that several times no joy, thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Still a solid router with dumaOS on it. Probably not worth some hammer-time. 🙂
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
