× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
MR60 Ethernet keeps disconnecting at random times
JacksonBroome
Every so often while I am using the wifi extender, my Ethernet and Internet will keep disconnecting at random times
Message 1 of 4
Guru
Re: MR60 Ethernet keeps disconnecting at random times
1. what modem/gateway is the router connected to?
2. what extender do you have?
3. Why are you using an extender versus the MS60 satellite?
Message 2 of 4
JacksonBroome
I have it connected to a Nighthawk pro gaming XR700, I have the nighthawk MR60 extender, I've never heard of the satellite version before so I believe I bought the MR60 when it came out before the MS60
Message 3 of 4
Guru
The MR60 isn't an extender. Its a router.
And the MS60 isn't an extender either. Its a satellite for the MR60.
If you have the MR60 connected to the XR700, the MR60 should be in access point mode.
you should also have it set with a separate ssid and different channels from the main router or they'll interfere with each other.
Not sure who told you the MR60 was an extender
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 250 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
