Rockman
May 05, 2016Aspirant
Apps Will not Download/Install to RN104
When I try and install any of the many available apps listed, the Progress Bar says "Downloading" and shortly thereafter I get a box that says "Apps operation failed" and "Aplication xyz cannot be downloaded at this time". This has gone on ever since I purchased the machine a couple of months ago and I decided to find out just what the problem is.
My ATT Uverse comes into their router and from to a hub in the office to the NAS box. I can download apps to my phone onsoftware to my Win10 PC on the same hub as the NAS all day long. I can download the apps ftom the ReadyNAS website to my PC with no trouble.
Any ideas would be appreciated?
Well, I have no idea what I did right but things seems to be working. I reloaded the OS for the upteenth time, set the static IP address for my network and rebooted. Suddenly RC "sees" the machine and the app downloaded/installed. Beats the heck out of me.
Just sign me as "clueless"
- mdgm-ntgrNETGEAR Employee Retired
Do your email alerts work?
If you set a static I.P. address on the NAS did you remember to specify the DNS server addresses?- RockmanAspirant
mdgm wrote:Do your email alerts work?
If you set a static I.P. address on the NAS did you remember to specify the DNS server addresses?Yes, the DNS Servers are all set. I tried to get email set up since you asked but unsuccessfully so far. Keepts saying "check smtp settings" and other than Outlook is set to SSL and this software says TLS, the Outgoing Server, Port, and id settings are all the same.
Is Outlook using an SMTP server?
- Retired_Member
The easiest way to check Internet Connectivity from the GUI is to click "Check for Update" in home page. If you get a message (Update available or not update available), it means Internet Connectivity is OK. If you don't get any message, it's not ;)
- RockmanAspirant
