Orbi WiFi 7 RBE973
Reply
RBK853
Johndj1
Follower
RBK853
Hi
I'm considering upgrading my broadband connection to 2Gbps and wanted to check that the RBK853 system had a multi Gb port I can use to maximise the speeds or if I need to upgrade?
Thanks in advance.
Message 1 of 2
Accepted Solutions
Guru
Re: RBK853
It looks like the RBK853 has a 2.5gig wan port.
https://www.netgear.com/home/wifi/mesh/rbk853/
It doesn't have multigig lan ports through
Message 2 of 2
All Replies
Guru
Re: RBK853
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 163 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
