× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
I have spent weeks trying to get my pixel 8 pro to work on the orbi 970
AbbasRaza
Tutor
Re: I have spent weeks trying to get my pixel 8 pro to work on the orbi 970
any updates on this new firmware update which would fix the pixel 8 issues?
Message 26 of 51
sgarr
Star
So, update. Even the Samsung 24 Ultra has started with the same issue, wifi calls are dropped which could be a handoff issue and sometimes the wifi will flip off back to data when next to one of the satellites just like the pixel 8 pro. There is one spot where I work if I don't move around will stay online next to the router. Maybe it will work some day.
Model version: Orbi 973
Firmware: V9.12.0.2_1.2.7
windows 11
Message 27 of 51
Guru
FYI, new FW available:
https://community.netgear.com/t5/Orbi-WiFi-7-BE-Mesh-Systems/New-RBE970-RBE971-Firmware-Version-9-12...
@sgarr wrote:
I have spent weeks trying to get my pixel 8 pro to work on the orbi 970. When I first got it every time the pixel would connect to the router, the router would immediately reboot. They gave me beta firmware which I think helped but sometimes would still kick the phone off the network. I presently have have firmware v9.10.2.3 on the router and I connect fine to the satellites it seems with the same firmware but if my signal gets handed off to the router it immediately kicks the phone off the network and the phone eventually connects fine to a satellite. Is any new firmware in the pipeline to help with this? I am writing this at 3am because I need my phone to connect reliably to this network. The orbi 960 system worked great with this phone and the pixel 7 pro for the past 1-2 years.
Message 28 of 51
sgarr
Star
Unfortunately this firmware update did not fix the issue. I am having the same issue with samsung 24 ultra. I changed phones from the pixel 8 pro to samsung thinking this would help. I still have a pixel 8 pro I can test so will see if it changed anything in the next few days. I have 4 satellites. When I walk upstairs with full signal wifi calls will drop or if I walk outside. I will have to manually disconnect from my wifi network and reconnect to resolve the issue but only if I don't walk to other rooms. However this issue is not as pronounced on the IoT network. Anyway I hope a solution will come some day.
Message 29 of 51
Guru
Does this happen with turning off all but one RBS?
Still happens if you disable the IoT and Guest Network?
What channel configurations are currently set on the router?
What is the distance between the router 📡 and satellite(s)🛰️?
Message 30 of 51
cmftblynu
Star
The only way we got ours to connect, was to use the IOT ssid, and dedicate that one just to the google pixel, and it seems to connect ok to that one only...
Message 31 of 51
cmftblynu
Star
That isn't your issue, mine are all hardwired (to a 10G wired network to boot) and can't get pixel 8 to connect reliably.  It has nothing to do with my sattelites, it is only google stuff...
Message 32 of 51
cmftblynu
Star
I worked with them directly for MONTHs they kept having me try beta firmware, nothing fixed it, they have no solution, I have no confidence in them figuring this out.  I only own apple products, it is my husband that has a pixel so he goes through hell trying to keep it connected...
Message 33 of 51
sgarr
Star
I have updated to the Google Pixel 9 Pro XL with the same issues. The new pixel may have a better algorithm for deciding when to use the cell network vs wifi calling but I have had two dropped calls this morning on wifi calling with wifi 7 on the Orbi 970/971. I have uploaded schematics with netgear support and sent all my phone and router logs. I have gigabit internet and 100% signal strength through the house with 4 satellites. If I stay in one place I can usually stay connected.
Message 34 of 51
TOPS119
Apprentice
I do t have seamless transition either once you disconnect from satalite one to another it’s not a seamless transition. Not even to do a speed test.
Message 35 of 51
Guru
Message 36 of 51
sgarr
Star
2789 square feet per google, 4 satellites for complete coverage plus 1 router, guest house not included in calculation. The wifi calls drop as I am looking at a satellite on the desk when coming into the kitchen.
Message 37 of 51
AbbasRaza
Tutor
To be honest, just forget about this system. I have given up completely. Orbi 6e (system before this) was their best mesh system with zero issues. This 970 is a NIGHTMARE!!!! I have resorted to Nest wifi pro (1 router and 1 mesh point) and it has been amazing for 3 months now with no issues at all.
Message 38 of 51
TOPS119
Apprentice
Google is garbage too but I must agree this Orbi system is not the best, this was the biggest waste of money in history
Message 39 of 51
AbbasRaza
Tutor
If google nest wifi pro is garbage then which wifi is actually good in the market right now? Fast and reliable
Message 40 of 51
AbbasRaza
Tutor
On another note... Is there a way we can get our hard earned money back for buying this stupid system!!!!
Message 41 of 51
TOPS119
Apprentice
Call it a lost my guy you ain’t getting a dollar back worst if you never bought it from them directly
Message 42 of 51
Guru
What's the building materials comprised off? Mostly wood?
For that size of home, you only need the RBR and 1 RBS. Having 4 would be too much: https://youtu.be/UR0viMLISz4
Would cause any wifi device to have problems picking and locking on to one good signal as there maybe too much and too much wifi over lap.
I have a 5K sq ft home and only run two RBS. I can get away with one RBS.
Can you try turning OFF 3 RBS and check with your device again?
Message 43 of 51
KevinLiT
NETGEAR Moderator
Hello Community,
We are aware that there have been issues reported with Google Pixel 8 on the Orbi Mesh 970 network. Please be advised that our engineers are diligently working with Google on a fix for this issue.
We appreciate your patience!
Best,
Kevin
Community Team
Message 44 of 51
Guru
Thank you Kevin.
Message 45 of 51
sgarr
Star
Hi Furry, what Wi-Fi 7 devices do you have connected and are you having any issue with Wi-Fi calling? Home is mainly wood, it is 5085 square feet If you include the guest house. The house is 3 stories and I have a satellite in the window to help give that area better coverage. The YouTube video at the end states that one access point per floor is good and that's pretty much what I have with one additional one in the kitchen. That YouTube video does not discuss Wi-Fi 7 however nor WiFi calling. I have disconnected two satellites before and just used one router with one satellite and I was not getting reliable gigabit internet with Wi-Fi 7 in each room. I added two more satellites to make sure that the internet connection would remain on Wi-Fi. 7 as much as possible in each room. The drop zones in the kitchen and porch and washing machine room do not occur with the additional satellites. The Wifi calling is the major issue when going from room to room. I unplugged two satellites again just to see what would happen and the internet dropped to 300 or 400 Mbps in the kitchen compared with 1Gbps and WiFi calling was able to hop on mobile network like usual sometimes it drops during this process. I have about 30 or 40 ft between satellites Netgear should state you can't have more than one satellite if it becomes unstable however, I have the same issue either way. Hopefully there will be some updates that will help with the Wi-Fi calling issues. I'm posting this with voice to text on my Google pixel 9 pro XL so I apologize if there are any typos.
Message 46 of 51
Guru
Thanks for the feedback.
Guess you'll need to wait then.
Message 47 of 51
TheBlackTruth
Same here.  They have been yanking me around with an open ticket and about half a dozen beta FW updates for the better part of 6 months now with zero insights as to what is wrong or why this is happening.
I have a Pixel 8 pro and also an iphone 15 I test with.
These taken within a minute of each other (pixel 8 pro on the left of course).
The behavior resets after toggling wifi off/on and then it occurs again with no particular trigger identified.  This seems to happen with other google devices as well such as my google TV, etc.
Message 48 of 51
CrimpOn
Guru
When these speed tests were performed, how were the two devices connected to WiFi?
  • If I read the specs correctly, iPhone 15 supports WiFi6 (802.11ax) with 4x4 MIMO and not 6E or 7.
    So the iPhone was probably connected to the 5GHz, WiFi6, correct?
  • Pixel 8 Pro supports WiFi7 (802.11be) with 2x2 MIMO.
    But it is not clear from the post what the connection was at the time of this speed test.
    (apologies if this was explained previously.  a conversation going back to Dec, 2023 is a bit hard to follow)
Thanks
Message 49 of 51
rushman
I just switched from an iPhone to a pixel 9 pro fold and this issue started happening. It has been happening with eight my wife pixel 8 since we got the system but you know because it wasn't happening to me, I didn't give it a whole lot of attention. Super frustrating and super frustrating that there hasn't been a fixed despite so many people having the same problem very disappointed
Message 50 of 51
Top Contributors
Discussion stats
  • 50 replies
  • 4240 views
  • 11 kudos
  • 10 in conversation
Announcements
Orbi 770 Series
