- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Intermittent connectivity/latency spikes/disconnects
- Mark as New
- Bookmark
- Subscribe
- Permalink
First the positives:
- speed is pretty mega when you are close to the router. I have a 1 gig fibre connection and getting exactly this over WiFi.
- range and speeds around the house do seem vastly improved. On my 850 I’d get 200 ish from satellite, now I get 700.
Now the downsides:
- random latency spikes when doing pretty much anything, maybe every 10-15 mins? It’s quite random. Typically when connected to satellite but also observed from router.
- device disconnections happen randomly and for no reason.
- ping-pong between satellite and router seems a lot worse than the 850 when roaming the house.
- latency when testing over WiFi from router (stood next to it) is worse on the 970 vs 850 by the tune of 5-7ms which is unexpected?
I’m on the latest firmware 9.12.2.1 on both and have identical setup from before with the 850. Both units in the same place, connected wirelessly. Router wired into ISP modem on high quality cat6 with modem on a 2.5g port/router 10g port. Same number of connected devices etc. Was literally a drop in place with change of SSID. Only other settings I’ve changed is disabling the iot and guest WiFi as not needed.
House is approx 200 sqm and router is ground floor and satellite on first floor, almost opposite ends to provide coverage across 3 floors. Router and satellite report “good” connection with 5+6 ghz shown.
I’ve tried hard resets and reboots and factory resets and all that. No real change observed. Wife is now complaining that even she feels it’s far worse than before (and she’s in no way technical).
I know this is a relatively new and expensive system so maybe not much uptake but are others facing these issues? I know home setup/building materials etc make every setup unique but shocked it’s worse than the previous much older system in terms of reliability.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Intermittent connectivity/latency spikes/disconnects
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
What devices are you connecting to the system?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/222...
Is the RBS showing 5+6Ghz in the RBRs web page under Connected Devices?
Armor, Smart Parental Controls or Traffic Meter.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- ISP is virgin media in the UK, using a super hub 5.
- router/satellite are ~30ft apart but have experimented and no change.
- not experienced any issues wired.
No other changes with devices which were all working perfectly fine on the 850 system.
I’ve tried disabling armour (as it’s useless anyway) to see if that helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the modem you have in modem mode or router mode?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
Satellite is showing 5+6 ghz connection with “good” displayed on the device page.
No MAC randomizers enabled. Devices used are a huge mixture - iPhones/ipads/macs/tvs/peloton/ps5/laptops etc. No issues previously.
Channel configurations all left on default except 5ghz which is on 48 (vs default 40). Can set this back to test if helpful.
Will try and test with satellite off - hard with some areas as WiFi doesn’t cover whole house (eg home office).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can you see if any Wi-Fi neighbors are near by your home and if there using same channels as the Orbi system is?
If channel 40 isn't being used or maybe one or two others that are far away distance wise, try channel 40.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Factory reset has been done since fw update, with satellite done first and then router as per guides here.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’m seeing random WiFi disconnects across today also on the main router (eg smart tv which is only a few ft away) and a few connected appliances which are constantly disconnecting randomly.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi is omni directional from what I know. Shouldn't need any pointing at each other. You can try of course turning each slightly I guess and see.
Can you post a screen capture of the RBRs web page by selecting the Advanced Tab, then Show Stats. Then post a screen capture of the debug page from the RBRs IP address/debug.htm. Please include this page from the RBS as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, I don't see any odd CPU or memory issues. Uptime is same across the two units.
I would open up a support ticked with NG support and ask for help on this one. We've seen some users with RBRs not working well out of the box and no matter the FW, didn't fix, however an RMA did so you may have a faulty system. I'd reference this thread as well.
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
Then clicking on "Get answers about NETGEAR products before I buy" then clicking on "Networking for Home" then "Chat with us".
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ya I agree. Let us know how it goes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Whats your iPhone model? Please list if its a pro model or not.
Which clients are you getting the most disconnects?
I have also messaged you privately asking for more details
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
@Kappo_84 wrote:
Recently upgraded to a new mesh - orbi 972 - to replace an “aging” 850 series. I was excited to pump enhanced 6E around the home as well as the (on paper) stronger wireless backhaul setup. Sadly my experience has been pretty poor so far for a £1500 system.
Now the downsides:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Kewl. Will be waiting for it as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I otherwise have a rock solid connection between router and satellite with almost max speed from the ISP connection (1gbps). Never had this issue with my old 850 setup. Pretty frustrating with all these issues given the cost of these units.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
