Orbi WiFi 7 RBE973
Reply
Orbi Power Adapter Voltage Label
sfobcn
Does the the Orbi Wifi Power Adapter (purchased in America), read 100V-240V on the label? Please advise! Thank you!
Message 1 of 5
genobkk
Star
Re: Orbi Power Adapter Voltage Label
I bought mine from Amazone shipped from the U.S. I am using it in Thailand  we use 220 volts here no issues.   Honestly I forgot to read voltage but if it was not 220 it would have fried the power adapter at least in 1 seconds
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 2 of 5
sfobcn
If you can look at the adapter, I would still appreciate to know what it
reads exactly! I live in Brazil and I bought a Arlo security system in the
US which I was assured (by Netgear support) that it supported dual voltage
and it did not! It did work for like two months and then stopped! That is
when I saw it read 100V to 120V after all (and getting a replacement base
was difficult)! Thanks!
Message 3 of 5
genobkk
Star
it says 110v-240v
Message 4 of 5
sfobcn
Thank you!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 7134 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
