Orbi WiFi 7 RBE973
Reply
Modem Dropout
lacamastraveler
Modem Dropout
My CM 1000 lately has lost communication.  Sometimes it quickly comes back on, other times I have to reboot and twice I've had to call TDS and have them send me a boost.
It went off around 10 am again today and I eventually had to reboot to get service back.  I have attached today's log.  Does this provide enough information for me to determine if I have a faulty modem or if another problem exists?  I travel a lot and depend on my WiFi for many house operations.  I can't reboot if I'm not here.  Thanks for all help.
Message 1 of 9
Accepted Solutions
Guru
Re: Modem Dropout
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem. Thats on them.
Message 8 of 9
All Replies
Guru
Re: Modem Dropout
Please post a copy and paste of the modems connection status page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-m...
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
Message 2 of 9
lacamastraveler
Re: Modem Dropout
The Cable Connection Status is Good
My Router is Synology RT2600ac with a mesh Synology MR2200ac in another location.
The cable is labeled Cat 5e
Are you saying you think the problem is not the modem, but the communication with the router?
Thank you.
Message 3 of 9
Guru
Re: Modem Dropout
WE need to see that data from the cable connections page. There is a long page there of data that you can copy and paste here in the forums so we can see the values there. Help to determine more if this is a signal issue rather then a modem issue. Many factors on the ISP signal can be a cause of modems not working right. The events log points to that already.
Message 4 of 9
lacamastraveler
Re: Modem Dropout
Frequency start Value
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
Starting Frequency
<tabindex=-1>Startup Procedure</tabindex=-1>
ProcedureStatusComment
Acquire Downstream Channel597000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnableBPI+
IP Provisioning ModeHonor MDDIPv4 only
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
ChannelLock StatusModulationChannel IDFrequencyPowerSNR / MERUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
1LockedQAM25631597000000 Hz-0.5 dBmV41.4 dB2469597500
2LockedQAM2561417000000 Hz-1.9 dBmV41.8 dB2342716600
3LockedQAM2562423000000 Hz-1.9 dBmV42.0 dB2343640300
4LockedQAM2563429000000 Hz-1.4 dBmV41.9 dB2344567900
5LockedQAM2564435000000 Hz-1.3 dBmV41.8 dB2345465700
6LockedQAM2565441000000 Hz-1.6 dBmV41.6 dB2346431400
7LockedQAM2566447000000 Hz-2.1 dBmV41.6 dB2347337300
8LockedQAM2567453000000 Hz-2.2 dBmV41.7 dB2348244700
9LockedQAM2568459000000 Hz-1.5 dBmV42.1 dB2349209300
10LockedQAM2569465000000 Hz-0.5 dBmV42.2 dB2350158600
11LockedQAM25610471000000 Hz-0.7 dBmV42.0 dB2351111400
12LockedQAM25611477000000 Hz-1.6 dBmV41.4 dB2352032800
13LockedQAM25612483000000 Hz-2.1 dBmV41.4 dB2352978500
14LockedQAM25613489000000 Hz-1.6 dBmV41.6 dB2353899400
15LockedQAM25614495000000 Hz-0.3 dBmV42.2 dB2354804600
16LockedQAM25615501000000 Hz0.5 dBmV42.7 dB2355776400
17LockedQAM25616507000000 Hz-0.1 dBmV42.3 dB2356743500
18LockedQAM25617513000000 Hz-1.6 dBmV40.8 dB2357660600
19LockedQAM25618519000000 Hz-2.1 dBmV40.7 dB2358575300
20LockedQAM25619525000000 Hz-1.3 dBmV41.4 dB2359502100
21LockedQAM25620531000000 Hz0.0 dBmV41.9 dB2360431700
22LockedQAM25621537000000 Hz0.8 dBmV42.6 dB2361348500
23LockedQAM25622543000000 Hz0.1 dBmV42.5 dB2362280800
24LockedQAM25623549000000 Hz-0.8 dBmV41.9 dB2363226700
25LockedQAM25624555000000 Hz-1.3 dBmV41.4 dB2364141300
26LockedQAM25625561000000 Hz-0.8 dBmV41.3 dB2365055500
27LockedQAM25626567000000 Hz-0.4 dBmV41.5 dB2366001000
28LockedQAM25627573000000 Hz-0.4 dBmV41.9 dB2366938200
29LockedQAM25628579000000 Hz-0.7 dBmV42.0 dB2367882200
30LockedQAM25629585000000 Hz-0.8 dBmV41.7 dB2368611100
31LockedQAM25630591000000 Hz-0.5 dBmV41.7 dB2369235400
32Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
1LockedATDMA112400000 Hz50.8 dBmV
2LockedATDMA217200000 Hz51.3 dBmV
3LockedATDMA323600000 Hz52.3 dBmV
4Not LockedUnknown00 Hz0.0 dBmV
5Not LockedUnknown00 Hz0.0 dBmV
6Not LockedUnknown00 Hz0.0 dBmV
7Not LockedUnknown00 Hz0.0 dBmV
8Not LockedUnknown00 Hz0.0 dBmV
<tabindex=-1>Downstream OFDM Channels</tabindex=-1>
ChannelLock StatusModulation / Profile IDChannel IDFrequencyPowerSNR / MERActive Subcarrier Number RangeUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
1Locked0, 1, 233741000000 Hz-0.7 dBmV39.0 dB148 ~ 3947689386620210450
2Not Locked000 Hz-7.2 dBmV0.0 dB0 ~ 4095000
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
1Locked3, 4, 5, 6, 9, 10, 11, 12, 13423525000 Hz52.0 dBmV
2Not Locked3, 4, 5, 6, 9, 10, 11, 12, 1300 Hz0.0 dBmV
Current System Time: Fri Apr 12 16:02:26 2024
Message 5 of 9
Guru
Re: Modem Dropout
Ok, signals and power levels on the line look good. Correctables and Un-correctables are zeros which is good.
The ISP needs to take a look at the events log and resolve those items mentioned.
Message 6 of 9
lacamastraveler
Re: Modem Dropout
When you say "items mentioned" which items are those?
Did the event log I attached to my original post help.  I've been down briefly and then back up since I began the last two posts.
I really appreciate your help.  The only way I will be able to communicate with TDS is to give them specifics, otherwise they will blame on my hardware.  They are most difficult to deal with.
Thanks, Jim
Message 7 of 9
Guru
Re: Modem Dropout
Message 8 of 9
lacamastraveler
Re: Modem Dropout
Thank you for your help.
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 648 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
