Orbi WiFi 7 RBE973
Reply
CenturyLink
neostinbuck
Follower
CenturyLink
Will my netgear c7000v2 router work for WiFi with CenturyLink????
Message 1 of 3
Re: CenturyLink
That is a cable modem router.What sort of Internet do you get from CenturyLink? Cable?
Which ISPs are compatible with my NETGEAR cable modem or cable modem router? - NETGEAR Support
You will have to ask CenturyLink if your modem/router will work on its network. There are just too many ISPs out there for Netgear to maintain an up-to-date and reliable database of compatible kit.
Message 2 of 3
Guru
Re: CenturyLink
Centurylink either uses fibre or dsl. Not a cable coax.
You'll want to check with centurylink to find out what gateway you can use. then you can connect pretty much any router to that (but not a modem/router combo device)
Message 3 of 3
Discussion stats
  • 2 replies
  • 256 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
