Orbi WiFi 7 RBE973
Reply
Nighthawk X4S D7800 is limiting my internet speed
ozgokhan0
Follower
I recently switched to More NBN FTTP 250/23M plan, from Tangerine 100/17 plan.
My Modem is Netgear Nighthawk X4S D7800
By connecting the UNI-D port directly to my computer via ethernet I am getting full speed of 260/23M. However, when I connect my PC via LAN ports on the modem/router, it gives me max 116 Mbps download. The upload is fine, I am still getting 23 Mbps. Called technical support but they were not very helpful because I am using a BYO modem.
*I configured the modem by entering the username and password I was provided.
*I updated the firmware (currently V1.0.1.68)
*The QoS is disabled. I even tried to enable it and set my bandwidth manually but still got the same speed.
The router/modem should be able to give up to 1Gbps. Can you please help me resolve this?
Message 1 of 2
Re: Nighthawk X4S D7800 is limiting my internet speed
The D7800 is a DSL modem/router.
What sort of Internet service do you have? NBN is not a technology so much as brand for Australia's quirky implementation of a raft of different Internet technologies.
What is an NBN network and is my NETGEAR DSL modem router compatible? | Answer | NETGEAR Support
and
Which NETGEAR DSL modem routers support NBN FTTN and FTTB SOS, ROC, and SRA standards? | Answer | NE...
You will see that Netgear makes not claim that your D7800 is compatible with NBN. But that does not mean that you cannot use it as a router connected to a different modem.
The first thing is to stop thinking about the D7800 as a "BYO modem". You need their help to use your own router behind whatever modem your ISP has provided.
What is this "UNI-D port"?
Yes,  but you need to use your D7800 in router mode.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Manually Set Up a Cable or Fiber Internet Connection
Message 2 of 2
Discussion stats
  • 1 reply
  • 278 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
