Orbi WiFi 7 RBE973
Reply
Movie to Insights but keep config
Night-Owl
Tutor
Hi,
I was looking at moving 5 switches to Insights management but the config apparently gets wiped when moving.
Is there a way to move them and re-apply a backup from the web based managed system they are currently on?
I won't be moving unless they is a way to move the config over because it's just too much work spending a full day reconfiguring them all.
Cheers.
Message 1 of 3
Qaswe23
Re: Movie to Insights but keep config
Transforming "Movie to Insights but keep config" involves extracting meaningful insights from a film while preserving its configuration or context. This process ensures analysis and understanding without altering the original settings or parameters.
Message 2 of 3
BrianL
NETGEAR Moderator
Hi @Night-Owl,
Local config will be erased since the devices will be onboarded in Insight. We have different configurations once it's added. I suggest that you take notes and screenshots and reapply the settings once you have your Insight Organization (if PRO) and location.
You can check this article for more information.
Kind regards,
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1037 views
  • 1 kudo
  • 3 in conversation
Announcements
