Orbi WiFi 7 RBE973
Reply
Topology showing unconnected wifi clients
sbs101
Tutor
Our network consists mostly of WAX610 access points which are connected managed via Insight Pro.
Since a few weeks (most probably after some update) the display in the "Topology panel" changed.
- Before it only showed wifi clients which were connected to the network at the time when one displayed the "Topology panel".
- Now it shows all of the wifi clients which have ever been connected to one of the access points at a previous point in time.
The number of connected clients is still correct in the list of the devices in the "Devices panel".
Is this a new feature or is it a bug? I sometime have to check which clients are currently connected to a certain access point which doesn't work with the current behavior.
The effect occurs in both our locations, independent on the fact, if in addition to the access points also switches are managed by Insight Pro.
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 165 views
  • 0 kudos
  • 1 in conversation
Announcements
