- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk R7000 MAC Spoofing Doesn't Work
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Nighthawk R7000 Router; trying to get it connect to Comcast/xfinity service on a Netgear CM400.
I'm having the problem where I can get the internet on a computer, but not on the router (the internet light stays orange). I've read the previous forum threads about others who have had this problem, and have read the kb article on mac spoofing:
http://kb.netgear.com/app/answers/detail/a_id/1086/~/no-internet-with-new-router---mac-spoofing
I have tried all of those things and I still cannot get connectivity. My current (not-yet-disconnected) service is a DSL connection through a similar DSL modem and the Nighthawk works fine, so I don't think it's anything physical. Is there some other setting somewhere aside from the MAC address (and I've checked it several times, entered it several times, so I'm fairly sure it's not a typo) that might be cause the Nighthawk not to talk to the CM400?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you are using your R7000 with your DSL connection, then it's probably set up to use PPPoE. You need to disable that before you can use the R7000 on cable.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk R7000 MAC Spoofing Doesn't Work
This absolutely worked; changed the "Does your service require a login" from "yes" to "no" (which eliminated the PPPoE thing), rebooted modem and router, and it's working like a charm. Thanks a ton!
User | Count |
4 | |
3 | |
1 | |
1 | |
1 |
