Orbi WiFi 7 RBE973
Reply
GS110TP bricked - help needed
slv_slv
Hello
I tryed to upgrade firmware of my gs110TP from 5.0.5.7 to latest at the moment 5.4.2.30.
I downoloaded 5.4.2.30 using TFTP as image2, activated it and rebooted switch
After reboot I can't connect or even ping my switch. I did it remotelly and at the moment I can't say what LEDs showing.
Before I started I read Release notes and there wasn't any warning about upgrading from prevoius versions. What I did wrong?
Is there any special intermidiate firmware to jump from 5.0.x to 5.4.x?
Help me please
Regards
Slawek
Model: GS110TP|ProSAFE 8-port Gigabit PoE Smart Switch
Message 1 of 6
Accepted Solutions
slv_slv
Betreff: GS110TP bricked - help needed
Hello
Power off and power on solved my problem.
Message 2 of 6
All Replies
slv_slv
Hello
Message 2 of 6
JohnC_V
NETGEAR Moderator
Re: Betreff: GS110TP bricked - help needed
Hi slv_slv,
Welcome to the community!
Thank you for sharing this on the community! Sometimes rebooting the switch resolves the issue. But take note that we cannot reboot the switch while it is on progress of doing an upgrade.
Message 3 of 6
genek500
Re: GS110TP bricked - help needed
Hi,
I have very similar situations, but after restart my switch doesn't work.
Do you know how upgrade this device via Console port?
Message 4 of 6
schumaku
Guru
Cold boot does not regain operations?
Officially, Netgear does not support using the (existing) serial port - in the box, on the PCB. Have an eye here in case you are willing (or need) to go this way, instead of sending the switch to service or replacement.
Many Netgear switch models are coming with a limited life time warranty (so some conditions apply - time in years since a product is EoL, first owner, proof of purchase, registration). Start this here on https://my.netgear.com select your switch from the list of registered products, and click on [Request Hardware Support].
FMI: LIMITED HARDWARE WARRANTY
Message 5 of 6
ReneD
NETGEAR Moderator
Hello @slv_slv,
It will be advisable to open a case with Netgear support for a hardware check. It seems your device failed on a firmware update and gone faulty.
https://www.netgear.com/support/
Have a lovely day,
Rene D
Netgear Team
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 3248 views
  • 3 kudos
  • 5 in conversation
Announcements
