× Get free training on Switching for AV over IP and receive AVIXA Credits. Sign up at NETGEAR.academy
Reply
Data VLAN 10 "add interface ip error
Nils-GSR
Setting up my network to run 4 VLANs for an a Audio Architect (AA) system that segregates default/native from Dante primary and secondary along with a second data VLAN for control of the AA. We are using 7 Netgear M4250's (GSM4248) switches. The default/native network is VLAN 1 (IP at XXX.XXX.0.XXX, mask at 255.255.0.0).
Trying to have segregation, the AA (also data) VLAN, is set as VLAN 10, with a static IP of XXX.XXX.10.XXX, masked at 255.255.255.0 and the Dante primary is set to static XXX.XXX.20.XXX, masked at 255.255.255.0, with the DHCP set to ON or Server.
With these settings I get the "Add Interface Error". I would like to segregate the two data environments (AA and Netgear Default) and retain the static settings of a very large AA design. Not sure what needs to be done to make this happen.
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 240 views
  • 0 kudos
  • 1 in conversation
Announcements
AV over IP Switches by NETGEAR
