× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
node.js or Meteor installation.
viperhansa
Virtuoso
Hi all.
Is it possible to run either node.js or Meteor on legacy Readynas Pro6 running os 6.4.0 ??
If so, which is easiest or best?
Best regards
Hans
Message 1 of 3
JennC
NETGEAR Employee Retired
Re: node.js or Meteor installation.
Hello viperhansa,
Since you are using OS6 on the legacy NAS you have, you should be using apps for OS6 too. Currently the ones at http://apps.readynas.com/pages/?page_id=9 are available.
You may also post suggestions and ideas at Idea Exchange board. Adding kudos to the ideas will help as development team will be reviewing the post that has the most kudos for considering it to add to the product's future functionality.
Message 2 of 3
viperhansa
Virtuoso
Hi JennC, thanks for your effort
Since this is posted under community add-ons i was asking for help from other users also, if they have been able to run either of the software in question.
I know about the apps pages, i have been a readynas user for ages..  🙂
On the apps page alot of apps are old and not updated and could create problems if installed.
I will create a post in the idea exchange board but i think that will be pointless since it seems that its very few users using that part of the forum.
regards
// Hans
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3612 views
  • 0 kudos
  • 2 in conversation
Announcements
