× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
transmission duo 2.42 - working settings
Deaf_Raiders1
Been trying all day to get this working, I keeps working for about 5mins then crashes with Connection Refused... get on my nerves now can't figure out what the issue is, Here is my settings.json (which were taking from this post https://community.netgear.com/t5/Legacy-NETGEAR-and-Partners-Add/transmission-duo-2-42-working-setti...
I am still on RAIDaitor 4.1.8 if i upgrade it transmission stops working.
"alt-speed-down": 50,
"alt-speed-enabled": false,
"alt-speed-time-begin": 540,
"alt-speed-time-day": 127,
"alt-speed-time-enabled": false,
"alt-speed-time-end": 1020,
"alt-speed-up": 50,
"bind-address-ipv4": "0.0.0.0",
"bind-address-ipv6": "::",
"blocklist-enabled": false,
"blocklist-url": "http://list.iblocklist.com/?list=bt_level1",
"cache-size-mb": 32,
"dht-enabled": false,
"download-dir": "/media/BitTorrent/",
"download-queue-enabled": true,
"download-queue-size": 3,
"encryption": 2,
"idle-seeding-limit": 30,
"idle-seeding-limit-enabled": false,
"incomplete-dir": "/c/media/BitTorrent/Incomplete",
"incomplete-dir-enabled": true,
"lazy-bitfield-enabled": true,
"lpd-enabled": false,
"max-peers-global": 120,
"message-level": 3,
"open-file-limit": 32,
"peer-congestion-algorithm": "",
"peer-limit-global": 100,
"peer-limit-per-torrent": 30,
"peer-port": 55893,
"peer-port-random-enabled": 0,
"peer-port-random-high": 65535,
"peer-port-random-low": 1024,
"peer-port-random-on-start": false,
"peer-socket-tos": "default",
"pex-enabled": false,
"port-forwarding-enabled": true,
"preallocation": 1,
"prefetch-enabled": 0,
"proxy": "",
"proxy-auth-enabled": false,
"proxy-auth-password": "",
"proxy-auth-username": "",
"proxy-enabled": false,
"proxy-port": 80,
"proxy-type": 0,
"queue-stalled-enabled": false,
"queue-stalled-minutes": 30,
"ratio-limit": 2,
"ratio-limit-enabled": false,
"rename-partial-files": true,
"rpc-authentication-required": true,
"rpc-bind-address": "0.0.0.0",
"rpc-enabled": true,
"rpc-password": "{d15b146a3063b3ade7d0fecaa9602218a327a8c8gOoal64v",
"rpc-port": 8181,
"rpc-url": "/transmission/",
"rpc-username": "admin",
"rpc-whitelist": "*",
"rpc-whitelist-enabled": true,
"scrape-paused-torrents-enabled": true,
"script-torrent-done-enabled": false,
"script-torrent-done-filename": "/c/addons-config/Transmission/email_alert",
"seed-queue-enabled": false,
"seed-queue-size": 5,
"speed-limit-down": 400,
"speed-limit-down-enabled": false,
"speed-limit-up": 20,
"speed-limit-up-enabled": true,
"start-added-torrents": true,
"trash-original-torrent-files": false,
"umask": 18,
"upload-slots-per-torrent": 3,
"utp-enabled": false,
"watch-dir": "/c/media/BitTorrent/sources/",
"watch-dir-enabled": 0
Please help it worked lastnight did not change anything, there was a powercut during the night.
Danny
Model: ReadyNASRND2110|ReadyNAS Duo 1TB (1 X 1TB)
Message 1 of 18
BrianL2
NETGEAR Employee Retired
Re: transmission duo 2.42 - working settings
Hi Deaf_Raiders1,
Can you confirm if other add-ons or devices services (ReadyDLNA, ReadyNAS Remote, File Sharing Protocols and etc.) are working fine? Perhaps, send us a copy of your logs so we can take a look.
Kind regards,
BrianL
NETGEAR Community Team​​
Message 2 of 18
Deaf_Raiders1
I can confirm if other add-ons or devices services are working fine  although
  • ReadyDLNA is not updating my media list on PS4,
  • ReadyNAS Remote which I don't use
  • File Sharing Protocols is working between iMac and Windows 7 computer
I will send you a copy of my logs when I get home maybe that will give you a good idea what is experience my issue.
Regards
Danny
Message 3 of 18
Deaf_Raiders1
This is what i get now
[IMG]http://i67.tinypic.com/2qio7k4.jpg[/IMG]
Message 4 of 18
BrianL2
Hi Deaf_Raiders1,
Can't see the picture from the link. Can you upload it here instead? Let's see if the app developer @super_poussin could help.​
Kind regards,
BrianL
Message 5 of 18
Guru
I could see it, so I'll repost it...
Message 6 of 18
BrianL2
Hi Deaf_Raiders1,
Have you tried other web browser/s or another PC?
Thanks to Stephen for posting the pic 🙂
Kind regards,
BrianL
Message 7 of 18
Deaf_Raiders1
Yes I have same thing.... now i can't access the NAS at all. I had to run and Resync after unplugging the power cord. The Blue light is blinking continuously i guess that is normal when doing re-sync
Message 8 of 18
BrianL2
Hi Deaf_Raiders1,
Can you tell the status of your ReadyNAS on the RAIDar utility?
Kind regards,
BrianL
Message 9 of 18
Deaf_Raiders1
The status is system starting up
Message 10 of 18
Deaf_Raiders1
I rebooted it. Now status is checking file system...
Message 11 of 18
BrianL2
Hi Deaf_Raiders1,
Is it finished? If not, try to perform Skip volume check
Kind regards,
BrianL
Message 12 of 18
Deaf_Raiders1
Nope still running this morning when I got up. Can't skip volume check I can't get into the browser or is there a method of button to press? I don't want to lose stuff on the NAS my final year of college work is on it but I only have some of the backup
Message 13 of 18
Guru
It's a boot option, not a web browser option.  See page 16 of your hardware manual.
http://www.readynas.com/download/documentation/HM/Duov1_NV%2Bv1_HW_en_06Dec11.pdf wrote:
For example, to perform a skip volume check, press and hold the Power button until all Disk LEDs flash once, after 5 seconds.
You do want to be careful on the duo, since there is no LCD panel to prompt you. But this particular option isn't very difficult.
One option is to power down the NAS, and connect disk 1 to a PC.  There's a freeware utility called linux reader that should be able to extract your data.  http://www.diskinternals.com/linux-reader/   Don't format the disk for windows of course.
Message 14 of 18
Deaf_Raiders1
Thank you i need to buy an external hard drive to transfer the data too 🙂
Message 15 of 18
Deaf_Raiders1
Right can't skip volume check lights still blinking. I just going back up it then factory set it
Message 16 of 18
Deaf_Raiders1
I can't view any of NAS drives with the link you posted StephenB. I was looking over this forums and found one called R-Linux that picks up my drive so I have to scan it and that takes 10hours. So I will leave that running while I am at work tomorrow.
Message 17 of 18
Deaf_Raiders1
Backuped finally done and NAS Duo as been restored factory setting, still get conenctions refused when trying access transmission.
Message 18 of 18
Top Contributors
Discussion stats
  • 17 replies
  • 5394 views
  • 0 kudos
  • 3 in conversation
Announcements
