× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Old and multiple files
Garthadam
Not sure how much info i need to supply. When i access my nas system through my Samsung smart tv I have video files that I deleted or moved that show up. I have also seen that some folders show double files where only 1 file exists.
Message 1 of 6
Guru
Re: Old and multiple files
What NAS do you have and what firmware are you running?
Are you using plex or readydlna?
Message 2 of 6
Garthadam
ReadyNAs 100, model RN104. Not sure on firmware or plex, readydlna. As i work away it would be about ten days before i get home to get that information
Message 3 of 6
JennC
NETGEAR Employee Retired
Hello Garthadam,
We apologize but you need to provide all important info about your NAS so we can identify where the problem started or could be causing it.
Message 4 of 6
Garthadam
Using readydlna and just updated firmware to 6.4.1
Message 5 of 6
JennC
Hello Garthadam,
Did you already try rebooting the Smart TV? This may have something to do with the LAN traffic travelling through the network. May be you can also try isolating the problem by moving NAS or the TV to the same switch (or router). If the NAS is connected to a switch, try connecting it straight to the router. Or if the TV is connected to the switch, connect it to the router.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2583 views
  • 0 kudos
  • 3 in conversation
Announcements
