× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
ReadyNAs DUO V1 RND2000 V1 - No Access Front view - RaidarOK
MikeFR2
Follower
Hello
My ReadyNAs DUO V1 RND2000 V1 was working perfectly
Since Yesterday I Can't access front view, can't access shares
Raidar found it (Model, Name, IP)
Raidar can't get firmware version !
When click on "admin page" I get
192.168.0.92 n'autorise pas la connexion.
ERR_CONNECTION_REFUSED
I've try
-reboot with and without disk
- reinstall firmware (Via USB) (as described here:http://kb.netgear.fr/app/answers/detail/a_id/24124/~/comment-mettre-%C3%A0-jour-le-micrologiciel-(fi...
Have you idéas ?
Can I get my datas back using a compter ?
Thanks in advance
Mike
Message 1 of 2
Guru
Re: ReadyNAs DUO V1 RND2000 V1 - No Access Front view - RaidarOK
If you are using the default xraid, then you could connect the data disk (usually disk 1) to a PC and extract the data with linux reader http://www.diskinternals.com/linux-reader/
The connection could either be sata or with a USB adapter/enclosure.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2308 views
  • 0 kudos
  • 2 in conversation
Announcements
