× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Trying to communicate with old ReadyNAS Duo
denbigh1974
I have an old ReadyNAS Duo (2012-ish?) that I am trying to get up and running using a Windows 10 laptop on the same wired network.
I have loaded RAIDar (Windows ver 4.3.8) and can identify the NAS IP address as 192.168.1.108. Using this, I can browse the files and transfer them to a back-up drive.
However, I can't seem to access the Duo setup. Any browser I use returns the message "The connection for this site is not secure. 192.168.1.108 uses an unsupported protocol."
Is there a relatively pain-free way to communicate with the NAS. My current thought is to back up all the files and then factory reset the device. But presumably I need to upgrade the firmware too? Is it possible?
The current firmware version reported by RAIDar is 4.1.16
Message 1 of 4
Accepted Solutions
Guru
Re: Trying to communicate with old ReadyNAS Duo
Starting here, 4.1.16 was the final firmware version for your NAS.  So there is no upgrade.
The error is because current browsers require TLS 1.2 for HTTPS and your NAS doesn't support that.
Use Firefox, and set security.tls.version.min to 1 (browse to about:config and search for the setting).   You will still need to click through a security warning, since the NAS uses a self-signed certificate.  But it will connect.
Once you are able to access frontview (and enable ssh if you haven't already done so), you can also modify a file on the NAS to let you connect with ordinary HTTP.
Posts 1 and 5 in this discussion thread might help:
Note the add-ons in the discussion thread that add TLS 1.2 to 4.2.x and 5.3.x ReadyNAS aren't compatible with your 4.1.x system.
Message 3 of 4
All Replies
schumaku
Guru
Use Firefox, call about:config and set security.tls.version.min to 1
Message 2 of 4
Guru
Message 3 of 4
denbigh1974
Thanks very much for your comprehensive solution.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 424 views
  • 1 kudo
  • 3 in conversation
Announcements
