- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
cant sync ready nas with samsung tv
- Mark as New
- Bookmark
- Subscribe
- Permalink
u was using plex on my samsung tv up until recently and now for some reason i cant use the plex app on my samsung i have plex pass is there any way to solve this problem also plex keeps asking for an update no idea how to get it
thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: cant sync ready nas with samsung tv
What version of the plex server are you running?
It is possible that you are being affected by this:
IMPORTANT: With the security changes in version 1.1.0, if your Plex Media Server is signed in to a plex.tv account, then all of the apps you use must also be signed-in. If you use older apps that cannot authenticate (e.g. LG's MediaLink or SmartShare apps), you can add the IP address of the device to the following advanced preference:Settings > Server > Network > List of IP addresses and networks that are allowed without auth.
(We strongly encourage apps to be signed in for improved security and enhanced functionality.)
Though the plex release notes don't mention it, if you are going to add your TV's IP address to the server configuration, then you should either reserve the TV's address in the router or make it static. Reserving in the router is best.
You can download plex server for ReadyNAS OS 6 systems from https://www.plex.tv/downloads/ Select "netgear" as the platform, it will give you a couple of options (x86, arm, RN2xx arm) after that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
im using this version
Version 0.9.11.7 An update is available. Please install manually.
but i cant update it and i cant sign in also when i try it says theres a prblem signing in
- Mark as New
- Bookmark
- Subscribe
- Permalink
ive tried downloading those what shd i do once they download nothing seems to work
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Download to your PC and then install on the system->settings page (manual firmware install).
- Mark as New
- Bookmark
- Subscribe
- Permalink
he document “plexmediaserver-ros6-binaries_1.1.4.2757-24ffd60_amd64.deb” could not be opened. Plex Media Server cannot open files of this type.
i cant open any of the links i downloaded for netgear its really weird
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you try installing it from the admin web ui of the NAS???
- Mark as New
- Bookmark
- Subscribe
- Permalink
can u pls tell me how to do that i cant figure it out
- Mark as New
- Bookmark
- Subscribe
- Permalink
Update file is not valid for this architecture. all the downloads for netgear if i try to upload them to my ready nas frontview page this is the msg i get so confused
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you using the GUI "Apps" page and then the "upload" feature on that page ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi karishmadan,
Follow bedlam1's suggestion on how to upload the add-on manually. Lastly, ensure that you've selected the right add-on type that is compatible with your system (ARM 6.x, Intel 6.x and ARM 6.x 200 series).
Kind regards,
BrianL
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
What firmware are you running on your ultra?
- Mark as New
- Bookmark
- Subscribe
- Permalink
i use raidar to connect with netgear readynas then open admin page and tehn add on and then try to upload is there any other way to do it
- Mark as New
- Bookmark
- Subscribe
- Permalink
firmware 4.2.28
- Mark as New
- Bookmark
- Subscribe
- Permalink
it says update not valid for this arcitecture i treid all three downloads under netgear so frustrated
- Mark as New
- Bookmark
- Subscribe
- Permalink
@karishmadan wrote:
firmware 4.2.28
As I said, Plex is providing downloads for OS 6 - you have OS 4.
Plex used to provide downloads for 4.2.x and 5.3.x firmware, but they deprecated those platforms last March.
It is possible to convert your NAS to OS 6 - though it is some work, and Netgear won't provide support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The instructions are in post #3 in this thread: https://community.netgear.com/t5/Using-your-ReadyNAS/OS6-now-works-on-x86-Legacy-WARNING-NO-NTGR-SUP...
You do need to backup your data first.
Then install the R4toR6 Prep add-on, then install the R4toR6 firmware image. The NAS will verify the image and prompt you to confirm you wish to reboot to install it. The NAS will automatically do a factory reset at the appropriate time avoiding the need for you to use the boot menu to do one manually.
Then you would restore your data from backup.
