- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can't shutdown Ready NAS rn104 with 6.1.4 RC3
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello
I have a VERY irritating problem. Everything time I turn off my NAS unit it just starts up again. After 3-4 sec. I have disk sleep turned off and auto standby schedule off. Anyone??????
Now I have to turn it off and quickly plugg the AC adapter.....
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I found the sollution myself!!!!
It was the addon VPN 1.5.0 that caused the change of MTU every system shutdown. As soon as i uninstalled it everything worked flawlessy again!!!!!
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can't shutdown Ready NAS rn104 with 6.1.4 RC3
Do you still have this issue if you update to the production 6.4.1 release?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have jumbo frames on AND Wake-on-LAN at the same time?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@h3nk3 wrote:
How do I turn off jumboframes. ???? Thanks for helping me out
Did you ever turn them on? They are off by default.
Log in to the web ui, and select network. Click on the settings wheel next to the ethernet adapter icon.
On the "general" tab there's a field called "MTU". Set to 1500 (if it isn't already) and jumbo frames are off. The NAS might prompt for a reboot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The issue identified by the support case will only occur if you have actively changed the MTU from 1500 to 9000. If you haven't changed the MTU, then your case is different to mine. Go to "Network" and have a look at your MTU. If it's 1500 and your box doesn't stay shutdown, it is a new issue. If it is above 1500, change it back to 1500 by clicking on the cog and reboot and see if a shutdown stays shutdown.
The below is a screenshot of my working legacy Ultra6 with jumbo frames (for illustration purposes), which works fine. My RN102 doesn't work with WoL and Jumbo frames and has an MTU of 1500.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello again
Mine was set to 1985.....instead of 1500.
Now everythings working with system shutdown again. What am I loosing here. Any performance loss from going from 1985 to 1500????
- Mark as New
- Bookmark
- Subscribe
- Permalink
1985 is a very strange value. It certainly should not have been set to that.
"MTU" stands for "maximum transmission unit". The value should be matched to the maximum packet size your network (e.g. your switch and router) can carry (taking into account the max packet size your PC NIC cards can receive). There are ways to test this - the most common is to use a utility called ping. If you google MTU and ping you'll find several guides.
The standard value for ethernet is 1500 bytes, and that is the NAS default.
9000 bytes is common for jumbo frmes, though some laptops in particular need smaller values. Sometimes enabling jumbo frames will improve performance, but in other cases it will actually hurt performance.
The reason it is inconsistent is that jumbo frames don't change the raw speed of your network. What they do is reduce the packet rate (larger packets mean that you send fewer of them). For some devices that reduces the CPU usage, but that is not always the case.
FWIW I use 1500 for my NAS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any thoughts???
Thanks Henrik Sweden
- Mark as New
- Bookmark
- Subscribe
- Permalink
I found out what causing the problem. If i power off the NAS unit the MTU changes to 1986 upon boot. If i reboot it stays at choosen value. 1500 MTU?
I'm wondering if anyone else having this bug/problem? Is there any sollution for this?
Henrik
- Mark as New
- Bookmark
- Subscribe
- Permalink
