- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ReadyNas Duo - kein LAN - keineLEDs
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hallo,
meine Readynas Duo ist im Netzwerk nicht mehr zu finden.
Die Dioden am LAN-Port am Gerät leuchten auch nicht mehr, Kabel und Router sind i.O.
Wahrscheinlich hat die Netzwerkkarte im ReadyNas Duo einen Schaden.
kann man die austauschen?
Danke
B
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: ReadyNas Duo - kein LAN - keineLEDs
Hi Basi,
Try these steps so we'll know if the chassis NIC card is still okay.
1. Turn off your NAS then remove the hard drives (label or mark them after removing).
2. Connect the ReadyNAS straight to your PC.
3. Boot it normally and see if the LAN LED lit's up.
I look forward to your response.
Kind regards,
BrianL
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
after removing the hard disks, the system keeps now for 1 hour in "starting mode". On-Off Button and yellow LEDs in front are flashing (twice long, three times short).
No LAN-LED is enlighted.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
The blinking pattern just means no disks inserted.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Basi,
Which ReadyNAS Duo is this? v1 or v2?
Do you have full back up of the data?
If you have a spare disk that is okay to format, insert it to the NAS' bay and factory reset. This will delete the current configuration on the NAS and format the spare disk.
Welcome to the community!
