- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
rn104 cant access after firmware update
- Mark as New
- Bookmark
- Subscribe
- Permalink
updated firmware now rn104 is asking for password for device, never has pwd
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello pdasterly,
That is unusual. I guess it is best for you to stick with 6.4.0 for the meantime, maybe until the official FW is released.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: rn104 cant access after firmware update
Which firmware did you update to/from?
How are you accessing the device e.g. via Windows Explorer on a Windows 10 machine?
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://community.netgear.com/t5/Using-your-ReadyNAS/rn104-freezes-on-shutdown/m-p/1009604#U1009604
from explorer on win10, worked perfect before 6.4.1
6.4.0 to 6.4.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
Which 6.4.1 build did you update to? The latest is 6.4.1-RC3
- Mark as New
- Bookmark
- Subscribe
- Permalink
reflashed to rc3, still cant access from explorer
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please send in your logs (see the Sending Logs link in my sig). Please also attach a screenshot showing the problem to your email.
- Mark as New
- Bookmark
- Subscribe
- Permalink
logs and screen sent
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you change the admin password? Are you sure you are entering the correct password?
Are you sure you don't have the old admin password saved e.g. in Credentials Manager?
- Mark as New
- Bookmark
- Subscribe
- Permalink
never had pwd
no problem accessing webpage
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello pdasterly,
Access to admin page always has password. If your computer never asked for it before, it must have remembered the password.
By default, username is admin and password is password. Please try that and see if the same.
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes, i can access the web admin page using pwd but win explorer wont accept pwd
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try running cmd (enter it in the windows search box)
net use * /delete
net use t: /user:admin \\nasname\data naspassword
That should mount the RN104 data volume as drive T. Let us know if that happens, or what error you get.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Microsoft Windows [Version 10.0.10240]
(c) 2015 Microsoft Corporation. All rights reserved.
C:\Users\admin>net use * /delete
There are no entries in the list.
C:\Users\admin>net use t: /user:admin \\nasname\data naspassword
System error 53 has occurred.
The network path was not found.
C:\Users\admin>
C:\Users\admin>
- Mark as New
- Bookmark
- Subscribe
- Permalink
The idea is to use the real nasname (or nas ip address) and the real NAS admin password in the two italicized fields.
Is that what you did?
- Mark as New
- Bookmark
- Subscribe
- Permalink
C:\Users\admin>net use t: /user:admin \\readynas\data naspassword
System error 1219 has occurred.
Multiple connections to a server or shared resource by the same user, using more than one user name, are not allowed. Disconnect all previous connections to the server or shared resource and try again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
System error 1219 has occurred.Multiple connections to a server or shared resource by the same user, using more than one user name, are not allowed. Disconnect all previous connections to the server or shared resource and try again.
That's why we start with net use * /delete
That error means the PC already has a connection to the NAS with a different user name.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You have these remote connections:
\\READYNAS\Downloads
Continuing will cancel the connections.
Do you want to continue this operation? (Y/N) [N]: y
The command completed successfully.
C:\Users\admin>
- Mark as New
- Bookmark
- Subscribe
- Permalink
Does using the IP address instead of the name change the result? The PC treats the IP address as a different machine from the name.
- Mark as New
- Bookmark
- Subscribe
- Permalink
C:\Users\admin>net use t: /user:admin \\192.168.1.149\data naspassword
System error 86 has occurred.
The specified network password is not correct.
C:\Users\admin>
C:\Users\admin>
- Mark as New
- Bookmark
- Subscribe
- Permalink
That command should be working (assuming you are typing the correct admin password for the NAS).
Perhaps try changing the admin password with the web ui. If that fails, contact support.
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes i tried to change pwd in web gui, also tried to set pwd under accounts.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello pdasterly,
Try disabling Windows password credentials
Control Panel > All Control Panel Items > Network and Sharing Center
Network discovery - Turn on network discovery (private and guest)
Public folder sharing - Turn on sharing
Password protected sharing - Turn off password protected sharing
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello pdasterly,
Go under All Networks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
