Orbi WiFi 7 RBE973
Reply
RAXE300 lost connection to Spectrum Modem
Newport92663
I have a RAXE300 and Spectrum Modem.  It has been working flawlessly for a few moths.  Today at midnight it "lost" connection with the cable modem.  By that I mean I do not get a connection via wireless or cable via the RAXE300 port.  The firmware is current and I have rebooted both devices mutiple times. I am able to hardwire directly to the cable modem, so i'm definityly getting internet .  Has anybody else experienced this issus with Spectrum and/or has a possible solution?  Thank you in advance for reviewing this request.
Message 1 of 4
Accepted Solutions
Guru
Re: RAXE300 lost connection to Spectrum Modem
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Was the Internet LED on top of the RAXE router amber when this happened?
Armor, Smart Parental Controls or Circle, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Message 2 of 4
All Replies
Guru
Message 2 of 4
Newport92663
Per the recommendation, I started the sequnce per instructions and it worked. Thank you for providing the solution.
Message 3 of 4
Guru
Ok, Happens again, might check the ISP modem connection as well. Check the logs on the RAXE for any Internet Re-connections. Usually means the RAXE has lost the connect from the modem or the modem stop giving services to the router.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 474 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
