Aches
Jan 04, 2020Aspirant
: Installing Orbi CBR40 and RBR20 in 2 buildings
I want to have I want to have WiFi in a garage150 feet away. In the main house I have installed CBR40 with 2 satellites and it preforms great. 150 feet away I have a 2 floor garage with a cement fl...
Jan 04, 2020Guru - Experienced User
What is the Mfr and model of this switch between the CBR40 and garage? Is this switch separate from the CBR40 or you referrging to the ports on the back of the CBR40?
Either way you could install your RBS at the garage at the end of the LAN cable coming from the house. I recommend putting maybe a 5 or 8 port non manged and non green ethernet switch in the garage, then connect the RBS to the switch and the switch to the cable from the house. The RBS will auto sync and setup the WiFi SSID and PW that is configured on the CBR40 in the house. Then you'll have wifi in the garage. And wired connections if needed too.
Aches
Jan 05, 2020Aspirant
The switch in the house is Netgear 24 port the switch in the garage is a Netgear 12 port POE switch.
- FURRYe38Jan 13, 2020Guru - Experienced User
Some switches may not work with Orbi. Managed switches or switches with Green Ethernet can impact Orbi. For managed switches, disable ALL IGMP protocols on these switches. Use non Green ethernet switches.
