cvt73
Jun 20, 2024Follower
1.0.0.1 gets redirected to one.one.one.one website
I have the Orby RBR050 mesh wifi router conencted to an AT&T modem. It has the 1.0.0.1 ip addres configured. I used to be able to log in to the router by just by typing in 1.0.0.1 in the web browser ...
Jun 24, 2024Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
cvt73 wrote:
I have the Orby RBR050 mesh wifi router conencted to an AT&T modem. It has the 1.0.0.1 ip addres configured. I used to be able to log in to the router by just by typing in 1.0.0.1 in the web browser but it stopped working Today. In both mozilla, chrome, brave and edge I get redirected to this cloudfare website one.one.one.one. Any ideas what is going wrong here, I searched everywhere but I can't find anyone having this problem. My PC is connected through a wired connection to the router right now but it behaves the same over the wifi.
