Retired_Member
Jun 21, 20171.11.0.20 Firmware Problems w/ Satellites
Both of my satellites along with the master router received the 1.11.0.20 update yesterday. Upon restart of all 3, the satellites and all clients attached to them no longer show connected in the ...
- Retired_MemberJun 30, 2017
I can confirm that the 1.12.0.16 beta corrects the sats not showing up in the Attached Devices and Firmware Upgrade pages of the router. Now if it is as good as everything has been for the past 6 months, except for the issue in 1.11.0.20 with the sats, I'll be in great shape!
quentin
Jul 10, 2017Aspirant
how i would get a copy of this version. 1.12.0.18 ?
I am using it version. 1.12.0.16
indomanna
Jul 10, 2017Tutor
I just go to firmware update tab and click check update. then i see status changed it's downloading firmware.
- quentinJul 10, 2017Aspirant
I'll try it !
thank you!!
- DarrenMJul 11, 2017Sr. NETGEAR Moderator
Hello nelsonahmed
You may want and try to re sync the satellite or if you know the IP address of the unit try to put that in your web browser and see if the GUI for the satellite unit shows up.
DarrenM
Hello Everyone
We have release firmware version 1.12.0.18 this firmware has fixes for disconnects and many more I posted the release notes below.
https://kb.netgear.com/000044171/RBR50-Firmware-Version-1-12-0-18
If you are still having issues after updating your Orbi unit you may want to factory reset the Orbi and test again. If you are still having disconnect issues or other issues with this firmware please create a new thread or contact our support team.
http://www.netgear.com/support/contact.aspx
Thanks
DarrenM
