Retired_Member
Jun 22, 20171.11.0.20 Firmware Problems w/ Satellites
Both of my satellites along with the master router received the 1.11.0.20 update yesterday. Upon restart of all 3, the satellites and all clients attached to them no longer show connected in the ...
- Retired_MemberJul 01, 2017
I can confirm that the 1.12.0.16 beta corrects the sats not showing up in the Attached Devices and Firmware Upgrade pages of the router. Now if it is as good as everything has been for the past 6 months, except for the issue in 1.11.0.20 with the sats, I'll be in great shape!
indomanna
Jul 11, 2017Tutor
I just go to firmware update tab and click check update. then i see status changed it's downloading firmware.
DarrenM
Jul 11, 2017Sr. NETGEAR Moderator
Hello nelsonahmed
You may want and try to re sync the satellite or if you know the IP address of the unit try to put that in your web browser and see if the GUI for the satellite unit shows up.
DarrenM
