joedoro
Jul 17, 2017Tutor
1.12.0.18 just made it worse
Purchased Feb 2017 and all was fine until several weeks ago with the 1.11.x.x firmware. Then whenever I had the satelite connected my internet was disconnected. Did all of the the stuff suggested...
DarrenM
Jul 18, 2017Sr. NETGEAR Moderator
Hello joedoro
So when the satellite is connected you are seeing the issues?
DarrenM
joedoro
Jul 18, 2017Tutor
As soon as I turn the satellite on is when I start getting the dropped internet connections if I turn the satellite off and wait a bit then the internet connection will be reestablished. Unfortunately where I'm online the resulting speed is then 1-2 Mbps.
