Anonom
Nov 09, 2019Guide
1 device cannot connect to new network
I installed a new mesh router yesterday (Netgear Orbi AC1200/RBR10 ) using the same SSID and password my previous router had. All my devices (around 10 of them) all work fine whether wired or wireles...
Nov 10, 2019Guru - Experienced User
Can you manually enter in DNS addresses into the Chrome books networking settings to see if this helps any? Enterin ISP DNS or 8.8.8.8
- AnonomNov 10, 2019Guide
I had previosuly tried the "Google servers" setting for DNS server on the Chromebook. I manually put in 8.8.8.8 but get the same error.
- FURRYe38Nov 10, 2019Guru - Experienced User
What are the security mode settings you are currently using on the RBR? WPA2 and AES only or a mixed mode?
FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too?
The modem is a Surfboard SBG6580. I just reset it which I should have tried before but since everything is working with internet I downplayed that end of it.
I am using just WPA2/AES.
