Anonom
Nov 09, 2019Guide
1 device cannot connect to new network
I installed a new mesh router yesterday (Netgear Orbi AC1200/RBR10 ) using the same SSID and password my previous router had. All my devices (around 10 of them) all work fine whether wired or wireles...
Nov 10, 2019Guru - Experienced User
Can you manually enter in DNS addresses into the Chrome books networking settings to see if this helps any? Enterin ISP DNS or 8.8.8.8
Anonom
Nov 10, 2019Guide
I had previosuly tried the "Google servers" setting for DNS server on the Chromebook. I manually put in 8.8.8.8 but get the same error.
- FURRYe38Nov 10, 2019Guru - Experienced User
What are the security mode settings you are currently using on the RBR? WPA2 and AES only or a mixed mode?
- AnonomNov 10, 2019Guide
FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too?
The modem is a Surfboard SBG6580. I just reset it which I should have tried before but since everything is working with internet I downplayed that end of it.
I am using just WPA2/AES.
Your ISP Modem already has a built in router. Try one of the following:
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopThe modem supports bridge mode so I would give this a try first. IF you don't know if you can get into bridge mode, please contact your ISP and they can help you with this.
This maybe the cause of the Chromebook not getting thru to the internet:
This would be a double NAT condition which isn't recommended.
https://kb.netgear.com/30186/What-is-Double-NAT
