Anonom
Nov 10, 2019Guide
1 device cannot connect to new network
I installed a new mesh router yesterday (Netgear Orbi AC1200/RBR10 ) using the same SSID and password my previous router had. All my devices (around 10 of them) all work fine whether wired or wireles...
Nov 10, 2019Guru - Experienced User
What are the security mode settings you are currently using on the RBR? WPA2 and AES only or a mixed mode?
Anonom
Nov 10, 2019Guide
FURRYe38 wrote:What is the Mfr and model# of the ISP modem the NG router is connected too?
The modem is a Surfboard SBG6580. I just reset it which I should have tried before but since everything is working with internet I downplayed that end of it.
I am using just WPA2/AES.
- FURRYe38Nov 10, 2019Guru - Experienced User
Your ISP Modem already has a built in router. Try one of the following:
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopThe modem supports bridge mode so I would give this a try first. IF you don't know if you can get into bridge mode, please contact your ISP and they can help you with this.
This maybe the cause of the Chromebook not getting thru to the internet:
This would be a double NAT condition which isn't recommended.
https://kb.netgear.com/30186/What-is-Double-NAT
- AnonomNov 10, 2019Guide
I turned off the wifi radios on the gateway. I was sure I had them off before, but Comcast sometimes pushes an update and I lose settings.
I tried putting the gateway in bridge mode. The Chromebook still does not have internet access on the main network but does on the guest. When I put the gateway in bridge mode, I am unable to connect to it either via wifi or ethernet cable. I've had to factory reset it several times to be able to connect again.
Basically, the changes I've made to the gateway are DHCP server off, Wifi off, gateway=bridged.
OKay- I figured out that the gateway IP changed from 192.168.0.1 to 192.168.100.1 after putting it in bridge mode. So I do have access to it again.
