Anonom
Nov 10, 2019Guide
1 device cannot connect to new network
I installed a new mesh router yesterday (Netgear Orbi AC1200/RBR10 ) using the same SSID and password my previous router had. All my devices (around 10 of them) all work fine whether wired or wireles...
Nov 11, 2019Guru - Experienced User
And the Chrome book does not connect at all thru the Orbi to the internet?
Anonom
Nov 11, 2019Guide
FURRYe38 wrote:And the Chrome book does not connect at all thru the Orbi to the internet?
It doesn't have internet on the primary network. It does have internet on the guest network.
I tried an old Chromebook and it is able to get internet on both networks.
- FURRYe38Nov 11, 2019Guru - Experienced User
Sounds like something is wrong with this book if others are working and other devices can connect to the main network....
- AnonomNov 11, 2019Guide
FURRYe38 wrote:Sounds like something is wrong with this book if others are working and other devices can connect to the main network....
That's what is baffling. It worked on my old network days ago. It works on the guest network and other networks I tried so there is nothing wrong with the wifi chip. I compared the settings to the other Chromebook and don't see anything different.
Ya, I know. Just points to this device though if others are working.
Try this, disable or set the security mode to disabled on the RBR temporarily. Save and apply. Then try to connect this book to the SSID with no security mode set. Does it connect or not?
Try WPA and TPIK setting and see. Re-enable WPA2 and AES after your done.
FURRYe38 wrote:Ya, I know. Just points to this device though if others are working.
I tried TPIK and no difference.
I am not sure if you meant wireless security or general. I tried making it an open network (no security/password) and that made no difference. I also previously had tried to turn off the general security (I think it is called Netgear Armor).
BTW, thanks for all the help.
I guess if I don't figure this out, at least I can still use the Chromebook on the guest network. I wasn't planning on enabling the guest network, but I guess it isn't the end of the world.
Security for the WiFi, is TPIK or AES. The mode is WPA or WPA2 or Disabled. If you can disable the WPA modems and yes, have the OPEN network temporarily to see if it connects. Re-enabled WPA after checking.
Sounds like this device is faulty though. I had a similar problem with a Samsung S7j phone this year. Phone would not connect to any SSID, security or not. Had to send the phone it and got it fixed. Turned out the wifi radio module was bad. Something you might look into with Google to see if the book can be fixed. - AnonomNov 12, 2019Guide
I'm probably going to just live with it. I am not sure a warranty claim (if it is even still under warranty) of 100 networks work okay but this one doesn't is going to go over well.
Unfortunately I was unable to try a USB wifi adapter due to they way Chromebooks work.
- FURRYe38Nov 12, 2019Guru - Experienced User
Ok, Good Luck.
- AnonomMar 17, 2020Guide
I have an update. After never solving this problem and a few other issues I upgraded to a different mesh router. My Chromebook connects to the main network without issue. I have also taken it on 3 trips and been able to connect to other networks without issue. The Netgear is the problem.
