Anonom
Nov 10, 2019Guide
1 device cannot connect to new network
I installed a new mesh router yesterday (Netgear Orbi AC1200/RBR10 ) using the same SSID and password my previous router had. All my devices (around 10 of them) all work fine whether wired or wireles...
Nov 12, 2019Guru - Experienced User
Ok, Good Luck.
Anonom
Mar 17, 2020Guide
I have an update. After never solving this problem and a few other issues I upgraded to a different mesh router. My Chromebook connects to the main network without issue. I have also taken it on 3 trips and been able to connect to other networks without issue. The Netgear is the problem.
