travist128
Dec 03, 2020Follower
110/120V Orbi AC2200 RBK23 Power Adapter Works on 230V/50Hz
Hello! I work overseas in SE Asia and bought the Orbi RBK23 AC2200 3-unit mesh wifi system from a US retailer, thinking like most electronics that they would come with 100-240V power adapters. Nope! ...
Dec 03, 2020Guru - Experienced User
Also long as the OUTPUT voltage and amps are the same, going into the Orbi device, the input don't matter. Just as long as your power adapter is dual voltage for regions that are 220/240v then your power adapter better be dual votage or rated to handle 220/240v on the input.
