travist128
Dec 03, 2020Follower
110/120V Orbi AC2200 RBK23 Power Adapter Works on 230V/50Hz
Hello! I work overseas in SE Asia and bought the Orbi RBK23 AC2200 3-unit mesh wifi system from a US retailer, thinking like most electronics that they would come with 100-240V power adapters. Nope! ...
schumaku
Dec 03, 2020Guru - Experienced User
travist128 wrote:Hello! I work overseas in SE Asia and bought the Orbi RBK23 AC2200 3-unit mesh wifi system from a US retailer, thinking like most electronics that they would come with 100-240V power adapters.
The worse part is that you receive FCC-only models from the us retailers, which can't be adjusted to any other wireless legislation - channels available and power makes operation abroad illegal. Very different, the non US/FCC versions (worldwide versions) can be adjusted, including to the US/FCC setting.
CrimpOn
I agree that the Region drop down menu in the Advanced Tab->Advanced Settings->Advanced Wireless Settings is greyed out. I have a strong memory of there being a way to reset the Region code, which would make the Orbi compliant with the actual location. (This will take some searching because it was maybe a year or more ago.) There are a bunch of parameters with "region=US". It could have been using telnet to reset one of the parameters or an HTTP hack to make the drop down menu appear.
- FURRYe38Dec 03, 2020Guru - Experienced User
https://community.netgear.com/t5/Orbi/ORBI-RBK53-Region-Change/m-p/1743684#M60468
CrimpOn wrote:
schumaku wrote:
The worse part is that you receive FCC-only models from the us retailers, which can't be adjusted to any other wireless legislation - channels available and power makes operation abroad illegal.I agree that the Region drop down menu in the Advanced Tab->Advanced Settings->Advanced Wireless Settings is greyed out. I have a strong memory of there being a way to reset the Region code, which would make the Orbi compliant with the actual location. (This will take some searching because it was maybe a year or more ago.) There are a bunch of parameters with "region=US". It could have been using telnet to reset one of the parameters or an HTTP hack to make the drop down menu appear.
