lowrisk's avatar
lowrisk
Tutor
Apr 01, 2019
1Gbit/s FTTH and Orbi ....
I changed my ISP for a new one which offer me FTTH (1Gb/s), and I want to optimize my setup.   I currently have my RBK53 use as AP mode only connected to my Synology Router.   My new ISP gave...
  • FURRYe38's avatar
    Apr 01, 2019
    Keep AP mode.
    You can't connect more then one LAN cable from the primary router to the Orbi base. Load balancing isn't supported on home class routers.
