rootzmanuva
Feb 10, 2022Aspirant
1gig speeds virgin broadband
Hi, Some advice would be greatly appreciated. I recently upgraded to virgin 1 gig broadband (I’m in the uk) with min. DL 560mb and UL50 mb. I’ve put the ISP router in modem mode to link up to my...
Feb 10, 2022Guru - Experienced User
300-400 is about what you can expect from wireless.
What speed do you get hardwired into the router?
- rootzmanuvaFeb 10, 2022AspirantWhen doing a samknows speedtest it is telling me 1gig plus is coming into the router. The ISP is saying it is fine too.
I’ve only got a smart tv and firestick wired in, which I don’t think are capable of getting 1gig. The firestick is getting around 300mv hardwired.- plemansFeb 10, 2022Guru - Experienced User
a firestick/cube/etc isn't going to max out a gigabit connection.
Again, try a pc/laptop
- rootzmanuvaFeb 10, 2022AspirantThanks for your reply
I will try this but when using the Orbi app speedtest, which to my understanding, tests the speed going through the Orbi router. It is maxing out at around 700mb (just now), which is an improvement from previous tests. Also, prior to setting up the Orbi, I used the ISP’s router, which showed plus 1gig to the router but lower than 500mb onwards to wireless devices. I would have thought stood next to the router doing a speedtest with a new iPhone I’d be getting closer to 1 gig!? I appreciate wireless isn’t going to be as good as wired.
Therefore, my thoughts are that the speed is ok to my house/router but from the ISP router onwards something is not quite right (regardless of whether the Orbi mesh system is in use).
