NikkiSLC
Mar 10, 2025Follower
1of 2 Orbi RBR50 satellite won't connect to Orbi router
1 of 2 satellites work. The other one continues to have a magenta ring. I have positioned it close to the router. I have reset the satellite. I have reset the whole system. It still does not work. Any...
Mar 11, 2025Guru - Experienced User
Can you access the self service web page on the RBS?
Can try this PDF process and see if the RBS can connect:
Be sure FW is same version on the RBS as what's on the RBR.
