OrbiMan
Dec 28, 2017Luminary
2.1.1.16 wifi stick more to 2.4ghz
Since the day I set up my Orbi system my phone always switched to 5ghz never really stay on 2.4 ghz until this firmware. Something changed and it needs to be change back
Hugenoot
Dec 28, 2017Tutor
Same here with my iPhone X, did a network reset on my iphone and problem solved...
OrbiMan
Dec 29, 2017Luminary
Yes reset or reconnect work but it shouldn't be that way.
- HugenootDec 30, 2017Tutor
I agree, and as far as I can see only the base Orbi works with 5ghz, and when i'm on the first floor the satilite connection is only 2.4ghz also with my wife's iphone 7. As soon as we gets near the base Orbi it's 5ghz again...
