Alex_07's avatar
Alex_07
Guide
Jan 22, 2018
2.1.2.18 Can't see connected devices
Hi,
I updated my orbi to the 2.1.2.18 firmware and since this upgrade, i can't see connected devices.
This is the only issue i have with it, all wifi options are active (mu mimo, beamforming ...) no disconnections.
Do you have a solutions without reset the router and satellite or are you planned an update to fix this issue ?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    That update did address issues with connected devices you may have to do the factory reset to see those devices.
    DarrenM
