dpdurst
Jan 22, 2018Luminary
2.1.2.18 crash after 1 hour runtime
Well upgraded this morning an hour later had a crash and both Router and Sat rebooted and went down. I never had this happen until this upgrade. Tried to attach the debug logs but you don't allo...
DarrenM
Jan 25, 2018Sr. NETGEAR Moderator
How often did the crashes occur?
DarrenM
- dpdurstJan 25, 2018Luminary
DarrenM wrote:How often did the crashes occur?
DarrenM
So I did the update manually to Sat first and then Router.
Both came up and were working fine. However the router was still saying it needed a firmware update in purple at the top after the reboot from the manual update. What I noticed was a short time later a reboot (the one mentioned) and then when it came back up there was a bit of trouble with the Sat connecting. So I powered both down and back up after just trying the Sync button. After my manual power down to get them synced back up its been fine since.
I suppose its possible that the router for some reason after the manual update thought for some reason it still needed to be updated and reboot for that, just a hunch. But since it came back online its been working fine with no issues.
DarrenM
