andyski101
Jan 18, 2018Aspirant
2.1.2.18 "Update Failed" & Satellite won't stay logged in
Trying to update my system to 2.1.2.18 from 2.1.1.16. The "Online Update" tab showed the update for my router and one satellite. The other satellite said "Upload failed". I then went to do the update...
DarrenM
Jan 19, 2018Sr. NETGEAR Moderator
I suggest contacting support if you can not get that satellite working.
http://www.netgear.com/support/contact.aspx
DarrenM
sleepr88
Jan 20, 2018Apprentice
I just want my money back (out of return window)... I will never buy, or recommend any Netgear product again... they have taken way too long to fix any of the issues with the Orbi system
- sleepr88Jan 20, 2018Apprentice
TP-link, Linksys, and others have already gotten it fixed... How long for a Chromecast/Android fix Netgear?
