CrimpOn
Mar 05, 2019Guru - Experienced User
2.3.0.32 Broke Orbi Logging
A reported in a previous thread Orbi does not handle log files the way it should. That issue (for me) was solved by doing a complete factory reset and reconfigure, a process that I now have down t...
- Mar 06, 2019
Yes, a "reset" and reconfigure from scratch has fixed the Orbi log problem. i.e.
- It seems to log what I expect: admin logons, NTP, sending email, DHCP, DoS.
- It sent a log after about 24 hours. Hmmmm. One of the settings is "once a day" (24 hours), which is NOT what is selected. So, it may be a coincidence that the log filled up in almost exactly 24hours, or...... (still not "doing what it was told to do") In a bizzare sense, this might be even better. i.e. if no log appears for two days, then it's broken again.
I'm marking this "closed".
Let us know if a reset fixes this...
