DB-Cooper
Mar 14, 2019Guide
2.3.0.32 Update - Orbi Satellite Password Not Working
I updated my Orbi RB50K to 2.3.0.23, hitting the stop gap at 212. All was well, I was able to update and login to my RBS to get to .212. After upgrading my RBR to 2.3.0.32, I was forced to change the...
Mar 14, 2019Guru - Experienced User
I take it you're trying to do the manual update if its asking for a password?
Does it work for the automated firmware upgrade?
Are you using a saved password manager to fill in the name and password? I've had automated ones fill in incorrectly.
It really doesn't take long to reset and reconfigure the RBS50. I know you don't want to do it but its probably the fastest way versus trying to guess/figure out the password issue.
