DB-Cooper
Mar 14, 2019Guide
2.3.0.32 Update - Orbi Satellite Password Not Working
I updated my Orbi RB50K to 2.3.0.23, hitting the stop gap at 212. All was well, I was able to update and login to my RBS to get to .212. After upgrading my RBR to 2.3.0.32, I was forced to change the...
ekhalil
Mar 14, 2019Master
DB-Cooper wrote:
.........but now I can't update the RBS firmware because it won't accept any password......
I don't get it, why do you need a password to update the Satellite?
I update my Satellite from the web GUI, through the Router as follows:
Have you tried that?
DB-Cooper
Mar 14, 2019Guide
When you click on that it prompts for password. This is if you do manual update.
I am using the web as well.
- plemansMar 14, 2019Guru - Experienced UserNext step would be to factory reset the rbr50 and resync during setup as the satellite should be syncing from the main unit.
- ekhalilMar 14, 2019Master
I am using the web as well.Are you able to login to the Satellite when you use a browser to go to http://192.168.1.2 (the Satellite IP address)? Try the default password if the Router's password does not work.
- DB-CooperMar 14, 2019Guide
Yes, when I go to the Satellite's IP, it asks for password, I've tried admin/router_password and admin/password. Nothing works.
Wow, I got it working. I changed the password from a very complex one with many non-alpha characters to a simple one, like "Password1", and it worked. So now I wonder if there is some limitation on characters that caused the Satellite to not work. Although my original password was 12 characters and had a $ in it, so who knows.
I also disabled the password recovery function, perhaps that did it.
I'll update and put the old password back and see what happens.
